A
AC Question
screen reader problem
When the screen reader pops up by itself without me turning it on in accessories it freezes almost every program installed an it keeps repeating every minite of time change constantly. You cannot shut it off because it won' let you access accessories to uncheck it to shut it down. The volume cannot be lowered. Normally holding the home button will display the accessories to uncheck and close it but when it in the screen reader mode that option is nowhere to be found. Swiping the face and tapping twice does not work in screen reader mode on. It took me on hour to close screen reader on my gear 6 by constant taping and I would like to complety delete it from my gear6 if tha is possible. Does anyone know how.swiping and I still do not know how I got it to shut off.
