A AC Question Apr 17, 2015 #1 Since the update, my LED notification light isn't working. I also downloaded an app to try and replace it, but this still isnt working. Will this get sorted? Or is there a way I can fix it?
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,364 110 63 Visit site Apr 17, 2015 #2 Welcome to the forums. What device are you using?
