How do I upgrade to Lollipop?
Sylvia Zinser
How to upgrade to lollipop...
This sounds like a stupid question - I had the notification that lollipop was available for my samsung s4 - and i must have clicked something (like "no thanks" or whatever...) so the notification does not reappear (like it always did with the prev. updates) . How do I still do this? 'my device' or any of the menu parts I checked don't get me any further, so where is the trick?
Thx
Sylvia
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Re: How to upgrade to lollipop...
There should be an option under Settings/About Phone (or a similar category) but it will be located under Settings app. Anyways you should find something about Check for Updates or Update Firmware, etc.. That should prompt the update to come back.
Junkie XL
