Cleaning up memory? Do u do it? How often?
tritan
139
on my blackberry if I cleaned the memory on my device it would run faster and wouldn't eat email and text messages etc. is this bedded on the droids? I have a droid x since july and have never cleaned it memory wise.
Sent from my DROIDX using Tapatalk
2CupsWithString
passionately curious
Jun 1, 2010
2,762
412
How's the X running for you? I'd say if it ain't broken don't fix it.
-- There are few ways to clean up some memory though, you can clear and apps cache & data if you want to, you can erase the system cache if you're rooted, etc. You could do a hard reset of the whole device and re-install everything.. there's a lot that can be done, it's my experience though that usually your device will run fine for quite a while.
RUSH
4,120
285
The two better methods would be to reboot/reset the phone. However, occasionally clearing cache, history, and cookies is a huge plus too.
RUSH
4,120
285
I'm not aware that resetting the phone erase's any of the phone's cache data?
Resetting the phone clears out everthing on the device... now the big question would be is >> what method of resetting are we talking about. A full complete or a device reset?
tritan
139
I use handcent, dolphin browser, and wonder if clearing recent calls list and missed calls etc help? I have around 5gb of internal memory how much should you have?
RUSH
4,120
285
Every little helps... maybe not in a significant or noticeable way.
Smitty_82
Android Addict
Aug 8, 2010
1,509
156
Whenever my x gets any lag it is usually due to the browser cache. I was in the habit of keeping the browser cleaned up on my bb so I tend to do the same. If you are but having any lag issues I would leave well enough alone.
cordoni
843
83
Here is my process to keep my fascinate running smoothly:
-clear the browser cache about every other use.
-Use "history eraser" to clean out call logs, etc about once a week
-Clean app cache every other week.
-About every 1-2 weeks I go through and delete unused apps I have downloaded to try that I don't use.
-Reboot the phone or clear non-excluded apps about every 3 days or if it starts lagging.
Sent from my SCH-I500 using Tapatalk
cordoni
843
83
Android is not as dependent on this as BB is though. I had to sim a battery pull almost every day on my old BB Tour pos. I think android is much more forgiving on caching, but 1ghz processors and 512 ram versus a 512mhz processor an 256 ram makes the big difference in even current BBs and mist android devices.
Pre-dawn raid
339
15
If you are rooted I use CacheMate (free and paid versions avail.) to auto clear my cache from a variety of apps, including the browser. The paid version includes hundreds more caches than the free version. I set it to auto clear every 2 days. A simple reboot (power off and then on) once a week also helps keep things running smoothly.
crxssi
Linux: The power beneath
May 31, 2010
2,668
155
Good God.... get a new phone cause you have something wrong! Evo: Never reboot it. Never clear anything. Never lags.
cordoni
843
83
Not that I necessarily have to do all of it but old habits from when I had a BB Tour. Figure it can't hurt.
vel7wil
428
26
I've beed using the app(app2sd) which when u open it will adivsed u how memory is in ur caches and if you want to clear them....so u can clear them all at once or one at a time....seems to get me running with little to no lag at all.......guess its one of those"to each his own" things
takeshi
969
30
It's only really an issue if you're running out of storage space. Take a look and see what's available. Keep in mind that storage space and RAM are 2 different things. Cleaning up storage space won't have much effect on your device's speed. Apps may run a bit better if cache is cleared bu it really depends on the specific apps in question.
If you're experiencing lag you may want to look into what's using up your CPU as well.
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
I clean the browser history and cache about once a week. Also have an app called History Eraser that I use. Android runs different then a BB so you really dont have to go crazy cleaning up the phone. As a ex BB user I know.....I had a ritual of clearing the browser, event log, caches, memory and rebooting the phone all the time....those days are over.:p
