Results 1 to 16 of 16
- 01-02-2011, 05:38 PM
Thread Author #1
Cleaning up memory? Do u do it? How often?
on my blackberry if I cleaned the memory on my device it would run faster and wouldn't eat email and text messages etc. is this bedded on the droids? I have a droid x since july and have never cleaned it memory wise.
Sent from my DROIDX using TapatalkMay the droid be with you !
- 01-02-2011, 05:43 PM #2
How's the X running for you? I'd say if it ain't broken don't fix it.
-- There are few ways to clean up some memory though, you can clear and apps cache & data if you want to, you can erase the system cache if you're rooted, etc. You could do a hard reset of the whole device and re-install everything.. there's a lot that can be done, it's my experience though that usually your device will run fine for quite a while.Fred
@thefredelement - 01-02-2011, 05:52 PM #3
The two better methods would be to reboot/reset the phone. However, occasionally clearing cache, history, and cookies is a huge plus too.
- 01-02-2011, 05:55 PM #4Fred
@thefredelement - 01-02-2011, 06:02 PM #5
- 01-02-2011, 06:09 PM
Thread Author #6
I use handcent, dolphin browser, and wonder if clearing recent calls list and missed calls etc help? I have around 5gb of internal memory how much should you have?
- 01-02-2011, 06:21 PM #7
- 01-02-2011, 06:29 PM #8
Whenever my x gets any lag it is usually due to the browser cache. I was in the habit of keeping the browser cleaned up on my bb so I tend to do the same. If you are but having any lag issues I would leave well enough alone.
- 01-02-2011, 06:45 PM #9
Here is my process to keep my fascinate running smoothly:
-clear the browser cache about every other use.
-Use "history eraser" to clean out call logs, etc about once a week
-Clean app cache every other week.
-About every 1-2 weeks I go through and delete unused apps I have downloaded to try that I don't use.
-Reboot the phone or clear non-excluded apps about every 3 days or if it starts lagging.
Sent from my SCH-I500 using Tapatalk"Give it time. You will be assimilated, resistance is futile. You are only here to serve the green R2D2. posted by HKM"
If someone helps you find an answer, please Thank them with the button in their post.
- 01-02-2011, 06:49 PM #10
Android is not as dependent on this as BB is though. I had to sim a battery pull almost every day on my old BB Tour pos. I think android is much more forgiving on caching, but 1ghz processors and 512 ram versus a 512mhz processor an 256 ram makes the big difference in even current BBs and mist android devices.
- 01-03-2011, 03:15 PM #11
If you are rooted I use CacheMate (free and paid versions avail.) to auto clear my cache from a variety of apps, including the browser. The paid version includes hundreds more caches than the free version. I set it to auto clear every 2 days. A simple reboot (power off and then on) once a week also helps keep things running smoothly.
- 01-03-2011, 05:36 PM #12
- 01-03-2011, 05:39 PM #13
Not that I necessarily have to do all of it but old habits from when I had a BB Tour. Figure it can't hurt.
- 01-04-2011, 08:36 AM #14
I've beed using the app(app2sd) which when u open it will adivsed u how memory is in ur caches and if you want to clear them....so u can clear them all at once or one at a time....seems to get me running with little to no lag at all.......guess its one of those"to each his own" things
Current: Samsung Galaxy Note II
Roms: Lab Rats LK8
Version:4.1.2
Hardware: L900.09
Baseband: L900VPALK8
PRI: ?
PRL: 55010
Kernel: 3.0.31-626403scinfra@SEP-83#1
Themes: Million Shades of Gray
Launcher: TW Launcher
Recovery: TWRP
Retired: Samsung Instinct,Palm Pre,HTC Evo 4g,htc Evo 4G LTE
- 01-04-2011, 08:39 AM #15
It's only really an issue if you're running out of storage space. Take a look and see what's available. Keep in mind that storage space and RAM are 2 different things. Cleaning up storage space won't have much effect on your device's speed. Apps may run a bit better if cache is cleared bu it really depends on the specific apps in question.
If you're experiencing lag you may want to look into what's using up your CPU as well. - 01-04-2011, 08:47 AM #16
I clean the browser history and cache about once a week. Also have an app called History Eraser that I use. Android runs different then a BB so you really dont have to go crazy cleaning up the phone. As a ex BB user I know.....I had a ritual of clearing the browser, event log, caches, memory and rebooting the phone all the time....those days are over.
Reply
