Why are my synced accounts periodically breaking?
B3Lz3bUb
Synced accounts periodaically breaking
Hi. I'm facing a problem of "Accounts & Sync" list randomly cleaning up, ie. phone background synchronization not available for almost all services.
Firstly I add all services I want to be synced. This works for a while but some time later all accounts except Goggle get lost from sync list, Worse off they're no more available for syncing. This usually partially resolves after phone restart so I can at least re-add all the services back. But later they'll disappear again and so on and on.
This appears not as problem of individual app as everything except Google loses ability to sync.
Desired 3rd party services are Viber, Pushbullet, Telegram, Whatsapp, Cyanogenmod account (not available persistently), MyLocalAccount(Mymphoneexplorer).
Another symptoms of the problem - all apps that should be synced are starting slowly when the problem occurs, also high CPU usage (no idle). Phone seems behave slower.
Need any clue to debug or solve the problem (possibly using logcat?).
These steps already proved not solving the problem:
- log out all google accounts and re-add them back
- clear all data for Google Play Services, Google Services Framework and Google Account Manager
- wipe dalvik cache
- move all synced apps to internal memory
Running Android 4.4.4 CM-11 rooted. Thanks for any solution!
fallingOutOfLoveWfithTech
