What's the best custom roms for Asus Zenfone 6? I tried to look for custom roms for Asus Zenfone 6 on the internet, but I cant find any? So, i need suggestions of the best custom roms for Asus Zenfone 6. Thanks.
That depends on what you're looking for. You flash a custom ROM because it has something the stock ROM doesn't have, and you want. The "best" one is the one that has the most things you want, which means that it's strictly a personal choice.
