Note 3 9005 to Lollipop 5 wifi issues, how can I get it working?
sam Zool
Please Help
Recently updated my Note3 9005 to Lollipop 5 and all I had is problems
1- Wifi Dropping out as soon as you move away from the router 1-meter range
2- Bluetooth issues voice not clear and connection dropping out.
3- Battery Drains Quickly
4- Generally the device sluggish
SO FAR
1. I have done a full reset,
2. cleared the cache in recovery mode
3. Took the device to Samsung Shop 50 miles away and they reloaded software and still no luck
4. disabled Mobile Data Mode
5. *#0011# advanced wifi power saver switch
Is there anything you suggest guys that might work please?
If you are using your home WiFi for the most part, be sure to update your phone's PRL (Preferred Roaming List) and Profile.
Go to:
Settings - General - System Update - Update PRL (Update Profile).
Make sure you are at home when you do this.
I had a similar problem . note3 wasnt connecting to home wifi so i upgraded it to lollipop. Then it wasnt connecting to any wifi. Subsequently i jus installed wifi doctor from playstore . It worked lke a charm. Now i connects to everything. A friend of mine also said that installing DNsetup and checking auto would have helped as weel. you can try . hope this helps
slackingfred
