- Mar 8, 2010
- 31
- 0
- 0
I wanted to attach a screenshot of just the share icon on my phone to a new post to AC. I want to post it directly such that when I view it in the posting, it is much smaller than the example image attached here:
Is there a way to somehow "shrink" the image after I post it here, or give the ATTACH directive[SUP]1[/SUP] some sizing options, or "shrink" it on the phone prior to uploading it? I don't want to have to use a desktop image editing program to reduce the size if I can at all help it.
Thanks,
-bg
[SUP]1[/SUP]If this is documented somewhere, then perhaps there needs to be a small "?" icon on the page that directs to a syntax help for these directives, such as ATTACH, for submitting new threads so that we could find the answer directly.
Thanks,
-bg
