A
AC Question
Contact Not Appearing While Dialing
When I start typing letters on the dialer, certain contacts do not appear in the list of available options. For example, I opened the dialer and typed "PELK" but no contacts with PELK in their name appeared. Other contacts with letters based on the keys used did appear.
Is there a setting on the contact record or the dialer that determines which contacts appear as you start dialing based on letters?
