Is it properly configured for it? Your carrier might need to send you the configuration or do it themselves (usually they can guide you through it via phone as well).
Who is your carrier, may need to set your APN settings, if they are correct then remember that MMS requires a data connection to work, so will need to have mobile data enabled..
