How do I know if the SD card is present or not through Android code/API?
A
AC Question
how to know SD card is present or not through android code/API?
I have a requirement to find whether SD card is present or not in phone in an Android application.
I have used following to check it, but it returns true, even if SD card is not present.
android.os.Environment.getExternalStorageState().equals(android.os.Environment.MEDIA_MOUNTED)
I did not find any proper solution which will work on different OEM's phone and tablet.
Quick help will be appreciated!
akbarramadhani12
