Can anybody help me with this issue? I seem to be able to select only 1 default number for a contact. Then this is used for calling and texting. I do not seem to be able to set different default numbers for sms/call.
Once this is set, how do I change it? Seems there are no options in contact>edit.
Also even if I set a default sms number, it uses this only from the contacts app. If I go to the messaging app and add contact from there, again it asks me to select which no. How can I remember which no. all the time?
Also where is groups in contact? I see no icon for groups or when adding new contact. Seems I can only do in google contacts on PC, sync and then menu>display>select group and unselect others. So from sms app, sending group sms is very difficult as it all the time asks for no., even if default is set.
Maybe way around is having contact shortcuts in folder groups, but how many to set and how to select at one shot for group sms? Use another sms app?
Am I doing something wrong? Coming from symbian, this I am finding very awkward. Even the basic nokia s40 had easy contact with icon for number type as well, instead of generic green phone receiver icon all built into OS.
Please help.
Please help.
