A
AC Question
Deactivate RTL
Hi there,
I activated "Developer options" to activate "Skip screen lock",
And for some reason the "Force RTL layout direction" activated a while after.
Every time I deactivate it, it activates as soon as I leave the developer options menu.
If I deactivate developer options by clearing data for the "Settings" app, RTL is still activated, while even "Skip screen lock" is reset to deactivated.
I'm using a Xiamo Mi3.
This RTL layout makes everything look out of place, and sometimes means I can't type properly (puncuation marks just magically get added to the beginning of the textbox).
If anyone might have seen this problem before, or might have an idea of how to resolve it, I'm all ears.
Cheers,
Victor
Hi there,
Cheers,
Victor
