The phone is saying no sd card or sim card, why?
A
AC Question
the phone is saying no sd card or sim card
II have tried everything that you said and it doesn't work
Tanya De la Morena
52
Re: the phone is saying no sd card or sim card
I recently had this issue, it turns out my SD Card was not compatible with my phone. I got it replaced with a 10 Class SD Card and the problem was fixed.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Both the SIM and SD cards at the same time? Sounds like a hardware failure on the board in the area of the card ports. Has the phone gotten wet or been in a high-humidity environment recently?
ParkerAdams
