A
AC Question
ES File Explorer problem, Cann't login shared folder
I have a home server used windows server 2012 R2, the laptop with windows 7 can access the shared folder, but the ES File explorer didn't.
The ES File Explorer can found the share folder but while I input the username and password there was a error message:
"Login fails. This may be caused by:
- WLAN is off
- SMB Server is out of network scope
- The IP is invalid
- Blocked by the firewall
- SMB service is off"
- WLAN is off
- The IP is invalid
