How do I open pdfs on my Droid?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,601
4,745
113
Welcome to Android Central! I moved this question to the General Help section, because the original forum it was posted in didn't allow replies. Where are you saving the PDF files on the phone? Can the Kindle app locate the PDF file in the first place but just not open it, or is it having trouble seeing the PDFs in the first place? Also check to make sure those PDFs can be opened by Adobe Reader on your computer--maybe the file itself is corrupt.
tress
