S4 Bootloop(Wont turn)Unless Battery removal then turns off in 2 seconds
Menkotucky
So, my Galaxy S4 turned off randomly yesterday during charge. I attempted turning it back on via the power button but it would not respond.
Then I tried taking out the battery and replacing it, the device vibrates with the Galaxy S4 logo showing up for about a couple seconds, then the screen goes blank again.
I cant turn it on with the Power Button.
When i remove the Battery and put it in again the S4 turns on shows the splash screen and turns after 2 seconds off
i cant do a hard reset or something its turning off right after 2-3 seconds
I even tried placing a battery from a different S4 - still doesn't work.
Anybody know what's wrong with my device?
Edit: Hitting the Power Button doesnt help.
Welcome to Android Central! Was the other battery you tried fully charged? If it was, then it might be a hardware issue with the power button, or worse yet, the motherboard. You'd probably have to bring it to a repair shop.
Osivourough
