Long-Press Doesn't Allow me to Add Apps, Shortcuts etc. to Home Screen
I use Nova Launcher prime. I use Folder Organizer for creating folder/shortcuts.
Up until yesterday, long-pressing on my home screen would prompt a menu asking if I'd like to add Apps, Widgets, SHORTCUTS (this is the necessarry part) etc.
Now, it just opens some weird menu where I can only add widgets or change wallpaper, or open Nova-Launcher's settings. Wtf?
I need to use Folder Organizer still! I need to get 'shortcuts' onto my home-screen >_>
Help?
Edit: I solved this buy using the FO widget in a really round-about way.
Still pretty mad that my whole menu structure was changed via update without my explicit permission to (either) the maker of Nova Launcher or Samsung. I don't know if a Nova or System update is responsible, but whoever is responsible know that I am pissed.
Help?
