Why won't my LG Tribute connect to any wifi?
A
AC Question
Lg tribute wont connect to any wifi
After downloading and running hotspot tether app from Google store my android won't connect to any WiFi. The WiFi shows saved secured but won't connect. Tried resetting phone but didn't work.
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
Re: Lg tribute wont connect to any wifi
Welcome to Android Central!
Did you uninstall the app that you used for the hotspot?
kirk781
