How do I delete a paired headset from a Samsung U680?
A
AC Question
I cannot figure out how to delete a paired headset from a Samsung U680. It doesn't give me an option anywhere to delete it.
hallux
Q&A Team
Jul 7, 2013
12,322
7
38
Re: How do I delete a paired headset from a Samsung U680
Go into Settings. In the Connections section (basing this off the settings on my Samsung tablet) and select Bluetooth, turn it on if needed. Once there, you should see a list of devices that have been paired to your phone, tap the gear icon next to the device you want to unpair and select unpair.
