How do I disable Odin mode (download mode)?
A
AC Question
How to disable Odin mode (download mode)
Hello guys
We're working in our organization on custom android phone to the employees, probably samsung made.
We want to block/disable odin from installing regular rom on the phone, there is a way to do it? how?
Thanks in advance
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
Re: How to disable Odin mode (download mode)
Hello guys
Thanks in advance
Welcome to Android Central!
If you are going to buy newer phones like the S6 or the Note 4 they have a security feature built in to KNOX that you can enable It is called Reactivation Lock, this basically locks the Bootloader from the OS side and prevents the phone from being re flashed with a new ROM or anything through download mode.
ParkerAdams
