How save a log when device reset?
Jun 19, 2015
First of all, i tried find something simillar without success.
Sorry if i this questions is already solved.
So, i would like to save the log of my Android before he reboot.
The problem is, i have an application running and sometimes the device reboot.
i know that this is caused by the app, however i would like to know why the app caused this.
There is a way to save the log before the device reset?
I'm using an MINIX NEO X5Mini running Android 4.2.
Thank you very much!
Best Regards,
Wilian Frare
w8wca
