How do I slow down the speed when adjusting volume levels?
A
AC Question
Adjusting volume levels
When I touch my volume key it goes from super loud to no volume without slowing down. How do I slow down the speed of the volume key, it goes from loud to off with one touch?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: How do I slow down the speed of the volume key, it goes from loud to off with one touch?
What device are you using? The volume should increase and decrease in increments. Are you able to adjust the settings via the settings > volumes menu?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,518
4,661
113
Instead of holding it down, just tap it multiple times to go down stepwise.
