A
AC Question
Outbound Calls being ID'd & Logged under 1 (incorrect)contact
Like many of you I am sure, I have many contacts within different companies and have a common business phone # (main line) and then their respective extensions.
For Inbound calls I get why my call ID is going to pick the "first" contact to ID using that common main line # as the reference.
BUT, on my outbound calls. When I select and call "Debbie".. the phone is then displaying "Mike" as who's being called, and also logging this as Mike in my Call history. When the call goes through it is the programmed extension for "Debbie's" that will pop up to auto enter - so I do get to Debbie.. but later in the day if I need to refer to my call history.. it only has Mike listed.
Does anyone know how to have the phone log the actual contact that was selected and to stop picking a "primary/lead" ID for common numbers.
I hope I explained this well enough. Thanks in advance.
