Perhaps the simplest way would be to send them as attachments to a text message or an email. The paperclip icon is for attachments....tap it, select Photos, then tap the photo you want to send.
But if you go to Photos, then tap the photo you want to send, then tap the Share icon - a triangle of dots with two connecting lines - you'll see other options.
