My phone doesn't ring after I have it on silent, why?
A
AC Question
my phone doesn't ring after I have it on silent
When I use the volume control to lower the ringer, once I turn it back up to full volume, it doesn't ring when a call is coming in.
tube517
2,505
63
48
Re: my phone doesn't ring after I have it on silent
Which phone? Some phones have a quiet mode that turns off sound during times you set. Make sure this is off if you have this feature
Sent from my Samsung Galaxy Note 2
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
I believe you have enabled a silent mode for calls. Go into system settings - sounds. Make sure that the sounds are set accordingly.
Robbyworkman1995
