Why is my LG Nexus 5 showing vertical lines.
My Nexus 5 is out of warranty. Its 15 months old. Today while it was switched on, I placed in on charge.
It was having 8% battery and when I checked after 3 hours, it was still having 8% battery.
I used the original charger and all I can see was these vertical white lines across the phone.
The phone was also super heated.
So, I switched it off. But the vertical lines are still there, each time I try to use it.
Sometimes it goes when the screen brightness is full.
Please advice if the phone LCD got damaged?
Please advice.
Please advice.
