How to speed connect wifi - easy
duypositive
10
Hey guys,
To day, I'll share some way to connect wifi faster.
1 - Avoid poor connections
2 - Capture wireless
You can use one object parabolic shape to focus the wireless signal and connection. You can use a metal bowl or cutting a can of coke or pepsi. This may not always be used but you also really it is a very interesting way if you made.
3 - Update firmware
4 - Delete bad connection
