Hi
I am a fan of Android.
I have two niggles, that I cannot quite find a definitive answer to
My network has just upgraded my Moto G to 5.1.My apologies if you had this upgrade earlier and seen these questions to many times
1. Is there a way, or thir party app that moves the Keypad lock to the Front home screen rather than having to flick up?
2 . Notifications. I like the icon notifications, but want to disable the alert sound and I think its a Vibrate alert for a few apps.
I have the main settings disable, but still I get the sound notificaitons.
I have tried via Seer app, but none work.
Has anyone had success in getting the icon notificaiton only? Or is a feature I have to live with.
Thanks, in advance for your help
