Phone is plugged in says its charging but its not, why is it doing this?
A
AC Question
Phone is plugged in says its charging but its not.
Also was plugged in over night off, said fully charged 100% but when I turned it on, it only had less than 30%. Just replaced the batt a week ago.
Jul 11, 2015
11
Re: Phone is plugged in says its charging but its not.
Something similar happened to a Galaxy Age I had some years ago. In my case it would say it was 100% charged, maybe only few minutes after plugin in, and, obviusly, after plugin it out, battery was exhausted only in a few minutes. Nothing solved the problem: I tried a new battery and Samsung Technical Service (which ended up saying that everything was correct!!!).
Sorry to say, but probably the charging circuit of the phone is broken.
