Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Jul 13, 2015 #2 Re: how to factory restore coolpad 5560s Settings/General/Backup and reset/Factory data reset. If you're bootlooping, or blew some of the ROM, that won't fix it, you'll have to flash the stock ROM. [Q/A]Coolpad 5560s - MegaThread: We are now … | Android Development and Hacking | XDA Forums might have some information, or you can post a question there. The OP evidently knows the device well.
