Why won't my Nexus play connect to my HMDX Rave Bluetooth anymore?
A
AC Question
why will the nexus not play blue tooth even though i have made sure it is turned on.
All of a sudden it has stopped connecting to my HMDX Rave. It has worked previously now it will not.
shel692
96
Re: why will the nexus not play blue tooth even though i have made sure it is turned on.
Have you tried removing the device and rebooting and adding back/ connecting again? Any new apps or app updates? If reboot/readd doesn't resolve and you can't pinpoint an app, next step is factory reset.
tress
