How do I root an Idea Magna 4035D?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: how to root idea magna 4035D
If it's running Android 4.4.4, you probably can't. If it's running 4.4.2, and the kernel date is June 2, 2014 or earlier, you can use Towel Root.
(Most single-market phones like that never get specific root apps - if a general exploit doesn't work on it, you can't root it without pulling the ROM, adding su to /system/bin, then reflashing it. And if you didn't follow that, please don't ask for instructions - they'd burn me at the stake for a post that long.)
