Re: how to fix low storage already cleaned out cachs partision
Clearing the cache partition does not affect space for Apps.
Install this simple little app called Storage Truth. It's very small and will install in very limited space. It will tell you how much space you actually have left for installing apps:
https://forums.androidcentral.com/e...pps/details?id=sa.storagetruth&token=wrOe_DUT
To make space you can:
Delete texts or emails. If you have a lot saved on the phone, this can help.
Delete or move photos, videos, documents, etc.
Uninstall app updates.
Uninstall apps.
Clear app cache files. However, this will only make space temporarily as cache files will rebuild over time. Also, while clearing cache files won't hurt anything, they're there to speed up operation and should be left alone.
If you can't move stuff to a SD card, move them to your computer or cloud storage.
Android since v1.0. Linux user since 2001.
