Lots of trouble with new 256 GB SD card, please HELP!
Hi! Thanks for the interest if you are reading this, I REALLY need some help.
So, I have a rooted Samsung Galaxy Mega 6.3 running KitKat 4.4.2. I rooted it with KingRoot a couple of months ago and everything was working perfectly. I have no custom ROMs or anything like that installed, I just wanted to be able to remove some build-in apps and have some other of the privileges we rooted-android users can have.
I was using a 16 GB SD card. Which only had approximately 2 GB left of free space. I was experiencing some unexpected reboots every now and then (even before rooting) and I read somewhere that my SD card might be the cause. So, since I download a lot of music I decided to buy another (bigger) SD card. I bought it from eBay (I am a broke college student) I read great reviews about it and it was relatively cheap.
Here's the problem: I move everything to the new 256 GB sd card, and I can't see any of my pictures in one folder. It takes a lot of time to be able to use it when it boots (which I understand, just trying to write all the details). I TRY to move my apps and it won't let me. So I remove it and I format it. It then says that I have 250 GB, even though I just formated it. Only then I am able to see all of my files and move my apps... and at least 3 of them show up in the menu with the Android icon and won't work. And some, like Facebook, keep giving me pop-ups with 'Unfortunately, (app name) has stopped working'.
I don't know what to do... Maybe it's my phone, or the quality of the SD card...
Any help will be very much appreciated!
