Android accessory sending AVCRP passthrough command for Volume +/- does not work
Hi,
I wonder if android supports AVCRP Volume increase/decrease command from an accessory ? I have developed a Bluetooth accessory which can send pause/play/next/prev/volume+/volume- AVCRP commands as in the AVCRP Bluetooth specification. All the commands work except for Volume+/-. I have not been able to locate a document which states which Bluetooth profile and commands or are supported by android. Thanks for you help !
Hi,
