Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Like Tree1Likes
  1. #26
    Default
    Quote Originally Posted by DroidXcon View Post
    i dont want to drop it because if we dont figure out whats wrong you cant help other people
    for some reason you are not even switching into the adb folder did you unzip the folder then place it on the C drive because this is what it should look like
    C>cd c:\quickadb
    then that turns into
    c:\quickadb
    but the picture you sent me doesnt switch directories
    when I type cd c:\quickadb
    it turns into just C>
    then I type cd
    then turns into C:\QUICKADB <--in caps
    then immediately goes to C>
    I'm sure i have the quickadb folder on root of c drive
  2. #27
    Default
    Hey DX wasn't there a proggy included in windows that let you remotely over the net control and browse another comp? I remember using something on win98 or xp that had that functionality. I'd be willing to let you muck around mine.
  3. Thread Author  Thread Author    #28
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by davey11 View Post
    yeah but im kind of busy at work i wont be free for like another 3 or 4 hours
    If i've made life easier buy me a Macchiato
  4. #29
    Default
    Why don't we wait till you get some free time and we could do it. Waiting for responses on here and posting screenshots is kinda tedious.
    Another option would be IRC...used to be a IRC addict ahwile ago
  5. Thread Author  Thread Author    #30
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    ok if you are on later we will try the screen sharing thing if its cool with you .
  6. #31
    Default
    ok just post in here, I get instant notifications...btw what is that screen share prog called?
    Im on W7
  7. Thread Author  Thread Author    #32
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
  8. Thread Author  Thread Author    #33
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Im on W7
    you ready davey?
  9. #34
    Default
    yep...want to go on irc? or can you converse in the team viewer? its installed btw
  10. Thread Author  Thread Author    #35
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    do you have a gtalk ? or irc whatever
  11. #36
    Default
    no gtalk...can install it tho whatever is easiest
  12. Thread Author  Thread Author    #37
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    yeah do that up if you can
  13. #38
    Default
    ok its web based...its up
  14. Thread Author  Thread Author    #39
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Just incase anyone wonders Davey's issue was resolved
  15. #40
    Default
    DX,
    I see what I did different...I was using the run button on the start menu and typing in "command prompt" which brought up the black command window.
    You typed "cmd" in the search files and folders field which also brings up the similar looking screen.
    Apparently those are 2 different things.
  16. Thread Author  Thread Author    #41
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    DX,
    Ah ok cool, i went back to the tutorial and put CMD in bold lettering so hopefully this does not happen to someone else
    Thanked by:
    ssethv
  17. #42
    wyllic's Avatar
    Posts
    ROM
    Eclipse 1.3 / PBJ non-oc
    Default
    you can also type cmd into the run box
    If you're going to be crazy, you have to get paid for it or else you're going to be locked up.
    -- Hunter S. Thompson
  18. #43
    ssethv's Avatar
    ANDROID OBSESSED
    Posts
    Global Posts
    1,587 Global Posts
    Default
    DUDE.... I am such a nerd!!! reading through this whole post was like watching a thriller type movie and being on the edge of my seat... thank you both for letting us know what happened... I don't even own a fascinate, but that doesn't matter. I do own a computer and something that simple could have or may have happen(ed) to me later on.... again... thanks to you both
  19. Thread Author  Thread Author    #44
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by ssethv View Post
    lol thanks but just so you know this will work for any android based phone
  20. #45
    Default
    seth.....You felt like a nerd??
    I felt like a weeenieee hahah
    It was quite a drama alright.
  21. #46
    Default Re: [How to] Quick ADB
    Man, shoot. I tells me that megaupload is down due to imfringment of laws... anbody know where I can find another copy of QuickADB?
  22. Thread Author  Thread Author    #47
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by indestructibleguy View Post
    I attached the file. all you have to do is decompress it have fun
    Attached Files Attached Files
  23. #48
    thank you! Trust me, I will.
