A
AC Question
soft bricked my phone, need help
I had a stock rooted verizon note 2 (sch-i605) running 4.3, wanted to enable OTA updates so I can get 4.4. I got triangleaway and reset flash counter, now I'm seeing "system software not authorized by verizon" message on boot. I tried flashing vruemj9 and vruand3 in Odin but it just fails. Any ideas? Here's the odin log:
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> I605VRUEMJ9_I605VZWEMJ9_I605VRUEMJ9_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/003> Odin v.3 engine (ID:3)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Initialzation..
<ID:0/003> Get PIT for mapping..
<ID:0/003> Firmware update start..
<ID:0/003> SingleDownload.
<ID:0/003> sboot.bin
<ID:0/003> NAND Write Start!!
<ID:0/003> FAIL!
<ID:0/003>
<ID:0/003> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
On the device it says "sw rev. check fail device:3 binary:2"
Thanks in advance
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/003> FAIL!
<ID:0/003>
Thanks in advance
