Re: why does my phone pause when I listen music and Pandora?
Welcome to Android Central!
Are you using headphones? Bluetooth speaker/connection? Usually the music will pause when it makes the switch to the aforementioned. If you are not, and it's randomly pausing, then I would suggest an uninstall then reinstall of those apps to see if that fixes your problem.
