Unfortunately monkey test has stopped, can I fix it?
  • Start date Start date
A
AC Question
unfortunately monkey test has stopped can i fix it
my device gallaxy e5 show when i start my data connection
Re: unfortunately monkey test has stopped can i fix it
Welcome to Android Central! That app or service is probably part of a "memory booster" app that you installed. Memory boosters are not helpful, and probably detrimental to your system (both in how they usually work, as well as how they often carry adware or possibly malware from the developer). Uninstall the memory booster app immediately. There are other threads about this, including this one: http://forums.androidcentral.com/ge...time-service-virus-how-can-i-get-removed.html
slackingfred
