This T-Mobile phone has had the Cyanogen mod, is now showing Android ver 4.4.2, which I would like to keep, but it has functional problems.
These might be solved by doing a hard reset, but if the rooting and modding destroyed the original T-Mobile Android system, what will happen if I do a hard reset on it? Will it keep the Android 4.4.2 OS it has now, just delete new apps & data? or will it be bricked, removing the mod but unable to put anything in its place..????
Thanks very much for all the explanation you can provide, at this critical juncture for the phone
