1. jjeffcoat's Avatar
    Is there any way to select a separate ringtone for incoming calls which do not match anyone in your contacts?
    02-01-2011 05:34 PM
  2. giograves's Avatar
    Man, this was a nifty feature (err um ...patch) on webOS.
    Looking for this for my Evo as well.
    Shadowhawk likes this.
    02-23-2011 05:17 PM
  3. Xopher's Avatar
    I don't know of a way to do this, per se, but you can assign people to groups and give each group (or individual) its own distinct ringtone.
    So, for me, family has a ringtone (certain people have their own tones), friends have a different tone, and so on. Anyone who isn't in a group (unknown callers) will get the default ringtone, which is what I use for unknown callers.
    02-24-2011 03:47 PM
  4. giograves's Avatar
    I can assign contacts to a group, but there doesn't seem to be a way to assign a ringtone to a group....at least with HTC Sense.
    02-24-2011 04:52 PM
  5. hellosailor's Avatar
    There's one kludge I use. I assigned a ringtone of "nothing.wav", which is a short recording of silence, to some of the "unknown" caller IDs.
    Depending on your service that may be "Out of Area" "Unknown caller" or a half dozen other terms. But if you take each of those, SAVE IT as a caller, and then assign a silent (or other) ring tone to it...that's what will play for all the same CallerIDs.
    If the cellcos weren't such greedy inconsiderate whores, they'd allow us to do what the better phone companies do: Just block all the calls without ID.
    Ain't rocket science, just greedy whores who are afraid they won't get paid for each call they allow you to block.
    02-25-2011 12:10 PM
  6. Convert2's Avatar
    WhoIsIt (paid) did it, but the app is not stable these days.https://play.google.com/store/apps/d...53aG9pc2l0Il0.
    I would pay for a simple app that would allow me to set a specific ringtone such as "who can it be now?" when a call is received from a number not in Contacts. This has great use when selling or renting stuff and your number is listed in an ad - want to pick up that call right away. There was this functionality built in way back in the Treo days and had it on my WebOS phones, but it is hard to believe that with all the high tech abilities on Android, this functionality is not available?
    11-09-2012 09:00 AM
  7. Scott Danks's Avatar
    Go into Settings -> Call -> Call rejection -> Auto Reject List -> "Unknown". Checkmark that number, and then exit the settings.
    Running Android 4.0.4 (Ice Cream Sandwich)
    10-07-2013 05:03 PM
  8. vMich's Avatar
    Belated reply, but if others, like me, are searching for this, this worked on Nexus 4 with KitKat
    1. Set the default ringtone to the ringtone you'd like for unknown callers.
    2. Get "Group Ringtones" app. Free.
    3. This allows you to assign a ringtone to "Contacts", allowing you to uncheck anybody you've already given a custom ringtone to.
    Done.
    (Haven't yet tested to see what happens when you add a new contact after doing this.)
    12-11-2013 09:43 AM
  9. Fontenele's Avatar
    Really belated reply, but I just wanted to provide a feedback should anyone see this like I did...
    Group Ringtones rocks! It is simple and very effective!
    Tks for the tip vMich!
    05-07-2015 07:39 AM
  10. CromeYellow's Avatar
    Yes this app Group Ringtones worked for me - I set it to make all Contact calls a certain ringtone, and then made the default ringtone a different one.
    10-21-2016 05:57 PM
