Here is the lines of code:
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.widget.SimpleExpandableListAdapter;
import android.app.Activity;
import android.view.View;
import android.widget.AdapterView;
import android.widget.ArrayAdapter;
import android.widget.ListAdapter;
import android.widget.ListView;
import android.widget.Toast;
import android.widget.SimpleCursorTreeAdapter;
import java.util.ArrayList;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
public class MainActivity extends AppCompatActivity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
//Prvi Deo
List<Map<String, String>> groupData = new ArrayList<Map<String, String>>() {{
add(new HashMap<String, String>() {{
put("ROOT_NAME", "Group 1");
put("ROOT_NAME", "Group 2");
List<List<Map<String, String>>> listOfChildGroups = new ArrayList<List<Map<String, String>>>();
List<Map<String, String>> childGroupForFirstGroupRow = new ArrayList<Map<String, String>>(){{
put("CHILD_NAME", "child in group 1");
listOfChildGroups.add(childGroupForFirstGroupRow);
List<Map<String, String>> childGroupForSecondGroupRow = new ArrayList<Map<String, String>>(){{
put("CHILD_NAME", "child in group 2");
listOfChildGroups.add(childGroupForSecondGroupRow);
//Drugi Deo
new SimpleExpandableListAdapter(
this,
groupData,
android.R.layout.simple_expandable_list_item_1,
new String[] { "ROOT_NAME" },
new int[] { android.R.id.text1 },
listOfChildGroups,
android.R.layout.simple_expandable_list_item_2,
new String[] { "CHILD_NAME", "CHILD_NAME" },
new int[] { android.R.id.text1, android.R.id.text2 }
ListAdapter casAdapter = new ArrayAdapter<String>(this, android.R.layout.expandable_list_content);
ListView raspView = (ListView) findViewById(R.id.raspView);
raspView.setAdapter(casAdapter);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.menu_main, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
//noinspection SimplifiableIfStatement
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
