Results 1 to 1 of 1
- 02-02-2011, 04:01 PM
Thread Author #1
Case for HTC Evo with Expanded Battery?
Hello All, I have an HTC Evo with a 3500 maH battery in it, and the expanded back casing. Does anyone have recommendations on some sort of cheap silicon or plastic case I could get that would fit?
I'd like something that comes on and off easily because I'd only use it when at the gym.
Thanks for the advice! -MattLast edited by jansenma; 02-02-2011 at 04:01 PM. Reason: Made it more clear the post is a question to the community =]
Reply
