google location reminders geofence too small.
I am used to apples version at first it was way too large sometimes 3 blocks away I would get the reminder they have gotten to better about 1 block or so. but I find using google to do it you pretty much have to be at that location to get the reminder and sometimes not even there. like I can get it two work at the two main stores I go to the yard two blocks apart but even a block away I won't get the reminder that need to go to one of them as I walk by. and when I use it to remind me to get something at Walmart as I walk through the parking lot or even i the store I don't get the reminder. so it seems it has a pretty small radius. is there any way to adjust it or another solution? I have a s6 it is the first android I have had so I don't know if it is phone specific.
