Irulu AX101 stuck on Irulu connecting my world, how do I solve the problem?
haresh domadia
3
irulu ax101 stuck on irulu connecting my world how to solve the problem
were can i download bootable operating system driver.
how to load in my tablet
i have try hard reset by pressing power and volum button
but nut not work
please send us your free advice i will be greatful to you.
Re: irulu ax101 stuck on irulu connecting my world how to solve the problem
Welcome to Android Central! Off-brand devices like yours have a higher incidence of defective firmware or hardware. It will be very difficult (if not impossible) to try to re-flash the stock firmware, because you'd have to root the device first (which you can't, if it's stuck on the boot screen), and then find the proper ROM to flash. If it's hardware defect, that won't matter anyway. Sorry! In the future, I'd strongly consider avoiding these kinds of cheap devices, and go for a more reputable manufacturer.
where can i get reflash the stock firm ware how to root the device first.were can get find proer ROM to flash hope will do the needful
You'll just have to search the web for that. XDA-developers.com is a good resource. But not all devices have a robust rooting community.
but nut not work
Hi Haresh
You may find the fitted drivers here at our site :https://www.irulu.com/download/lists.html
If anymore problem, now I'm here to help.
slackingfred
