Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Default xolo secure 6 digit pin forget
    I forgot my all details for xolo secure .like 6 digit pin and unable to recover from google
  2. #2
    B. Diddy's Avatar
    Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: xolo secure 6 digit pin forget
    Welcome to Android Central! You may be out of luck. These passwords are important--if you're prone to forgetting them, I suggest next time that you write the password on a piece of paper and keep it somewhere secure at home, like in a safe.
    If you fail the unlock enough times, does it ask for your Google credentials? I hope you didn't forget those.
  3. #3
    Hsadjen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: I forgot the pin to my Xolo password, how can I get into my phone?
    If you saved it on SD card or backup? you can be able to recover them from android phone, first , you should find a effective recovery tools to get them back,i wish you the best of luck ,
  1. Can't Login with Xolo secure to Google Account
    Last Post: 05-14-2016, 05:32 AM
  2. I forgot my anti-theft pin what can i do.
    Last Post: 09-22-2015, 04:14 AM
  3. New security flaw, by passing the lock screen
    By dt81 in forum Samsung Galaxy S6 edge+
    Last Post: 09-21-2015, 05:07 PM
  4. I cant get into my Secure Box
    Last Post: 09-21-2015, 03:30 PM
  5. Replies: 1
    Last Post: 09-21-2015, 11:15 AM
