I just switched from Windows Phone to Android (Lumia 1520 to Galaxy Note 5) and I'm thinking of switching back. The main reason is lack of voice support, mainly when it comes to texting.
It's so integrated into the Windows OS that I took it for granted. Windows could do it natively back in 2010 when Windows Phone 7 came out. You didn't need to download or run any apps to do it. Just put a Bluetooth headset on and it works.
If Person X sends me a text, I'll hear the notification and then it will say, "You've received a text from Person X. Should I read it or ignore it?" If I say "Read it", it will read the message and then ask if I want to reply or if I'm done. If I say reply, it will ask me to say the message and then read it back to me for verification and ask if I want to send it, add more, or try again.
What's the best way, if it's even possible to get close to this level of functionality? I understand I may have to start an app or something and I don't mind if it's not exactly the same. I just need to be able to listen to and respond to texts while driving. When I switched to Android, it didn't even occur to me that Android wouldn't have this level of basic functionality.
