Either I've forgotten my pattern or somebody has pranked me, as I cannot access browser, camera etc. Since the screen lock has a different pattern I can access most of the other features. Device Infinity Hot Note 2.
Thanks.
(ps: suggestions suggested on another forum:
In Settings>All>Apps>, select AppLockService, stop it, and try clearing its data
Tap AppLock icon to start AppLock.
If you are using pattern lock, please change to number lock.
Tap the 'forgot password' or '?' .
If you remember security answer, you can reset your password by security answer.
Enter your security answer.
Reset your password.
Check in Settings/Security/Device Administrators for AppLock, and if present disable it.
but nothing worked.)
Thanks.
